a1
Forum Founder
- Feb 6, 2008
- 10,184
- -1
I do all the tests you mention abaove and record them in the "Results" section on Schedule of inspections (Column 15 - on the example 'standard forms' in BS7671:2008 or GN3) this shows that you have done the tests.
I also do the r1+rn/4 and r1+r2/4 and put them there too.
If it is a 30mA RCD protecting a circuit equal to/more than32A supplying equipment being used outdoors, I aslo do the x five delta nRCD test and make an extra column and add the result there too.
And Good Luck on your Assessment.
