Robin Spark
- Aug 30, 2009
- 1,425
- 0
Well for the last 6 months we have had an intermittent leak from our system boiler (y plan) resulting every now and then with some water on the floor underneath the boiler itself. The boiler is in our converted garage.
We have central heating cover, used to be with BG but now its with another ONE (annagram) who are always really slow to come out and have had 4 engineers who have not fixed the fault.
After i removed boxing in for them the last time, I could see it was a drain off valve leaking and the guy said he resealed it. This was about 2 months ago.
Came back home from work week last monday to find rcd had tripped and located fault to boiler (easy guess really as i could see the water on the floor).
Phoned that ONE energy company and even though the Mrs has a disability and its going to cause her health & safety problems we still had to wait until friday for next available engineer.
Engineer guy turned up, i told him what the fault was, he said he would put a new seal in the drain off valve. He needed to drain down system so i turned off water for him and left him to it.
Later made him a coffee, and he informed me the drain off valve had been stuffed with paper towel (obviously by previous dxxk head) and he has now properly sealed it.
He went round the house bled all of the rads but wouldnt go into the loft as we dont have proper loft ladders just use extending ladders, however i told him hot water cylinder etc is right by hatch. He wasnt interested!
10 mins later he left and said everything sorted.
Friday night I was away and had a text from Mrs "loud grinding noise from loft, turned off heating as engineer has left it on"
Following morning another text from Mrs " no hot water, blah blah blah!!!!"
She called them up as i was in sunny wales Llangollen (first time in 10 years been away from home without Mrs) got to wait until thursday for them to come back out.
Got back home sunday, knocked the hot water and heating on, but the pump in loft is now not working but it gets really really hot! there was also loads of air in the pipes as the layout is pump then vertical section of pipework then 3 port valve then a little section of pipework leading to a soldered bleed valve which i loosened off to bleed the pipework.
So im thinking he had left the pump running for hours with no water going through and now its seized up.
However according to the Mrs its all my fault for going away last weekend!
