if plumbers rate the stuff well then it shows what the plumbers of today are like.
even if installed neatly with proper support, the fittings look damn ugly in comparison with end feed fittings... and not sure it actually does work out much cheaper, when you factor in how much the fittings cost compared to the end feed ones.. end feed ones are pence, plastic fittings are a few quid some of them. so it probably balances out.
I suspect only reason plumbers like it is because of speed, and if it is cheaper... but it shows they have no pride in presentation of their work however well its installed.. its just not possible to aesthetically install plastic pipe as tidy as copper, the fittings are what let it down... big bulky fittings.
