Hello all, As the title says nusiance tripping. headbang
From the meter I have a 100A/100ma S type rcd, from this the tails feed two connector blocks, then a MK 12 way split load consumer unit/100amp Dp switch and 80Amp/30ma RCD from one set and the other set to a Wylex 60 amp/dp switch fuse and swa to the farm outbuildings and my joinery workshop.
My spark recently replaced the old voelcd with the new s type rcd citing regulations deemed it necessary. Earthing system is TT. Overhead cables in the sticks.
Up until that everything was fine. Do I need the old voelcd replaced?
Have not spoke to my spark yet and was hoping to get some other advice first. Thanks.
