Just opening this in the event that any other SPH inverter users on here may have seen anything like this before.
I've documented the system install in previous posts but since final sign-off in early Feb everything has run pretty much as expected.
HOWEVER
Evening of Thursday 16th May at 20:55 the system suddenly switched from drawing power from the battery to taking it from the grid despite the battery state of charge being in the mid 70s%. System is set to Load priority.
After about 40 mins it then switched back and resumed drawing from the battery.
Power consumption at the time was a few hundred watts and no high power devices were switched on/off and I have nothing about that's on a timer.
Obviously concerned as to what was behind this, so kept an eye out to see if it was the start of something a bit more serious. (newbie obsessive
Suffice to say in the following days the system behaved as expected. Power drawn down from the battery overnight and no switches.
I also trawled back through previous months of data and couldn't spot anything similar having happened before.
So I was of a mind to believe the system may have had an update or ran a self check or something which took it off-line for awhile and that was it.
THAT IS UNTIL the following Thursday the 23rd when at 20:55 the system repeated the same sequence as the previous week.
The timing may just be a coincidence but I'm not generally a fan of those.
Anybody seen anything like this before?
If it does it again, particularly if its next Thursday
, I'll run out to the garage and see if there's anything on the inverter display (Status!) that might give a clue.
Ether way I'll update the post.
HOWEVER
![Confused face :confused: 😕](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
