I think , back in the day , there were around 100,000,000 less things to worry about regarding rules & regs .
I remember an incident that must have heralded the beginning of the The Great Increase in Rules & Regs .
Its was actually two non compliances picked up by the NIC man back then , I was a foreman for a contracting firm then , had to take the guy round a job .
1) At the mains we had some 4 X 4 metal trunking and we'd branched off it with some 2 X 2 ... the spark had made a cut out in the 4 X 4 , bolted a 2x2 flange on and he had some grommet strip cut ready to fit in the hole . The inspector reported it as "not conforming " , trunking hole without grommet strip , "Theres the Strip , right there" I'm saying ...."No its not in the hole " says he . !!!
2) Then he ,s looking at a 32mm KO box for a switch , in a stud wall ,plasterboard, wired in pyro . The plasterboard sat on top of the box , Inspector says the box should be flush with the front of the board ...because a fire could start in the switch & catch the paper edge of the cut board and the whole wall would be on fire . :C I think that when I started to give up .
