Oh it’s doable, the issue being that it’s covered by specific requirements and laws.
The logic of what you want to do is no different to the old bathroom without a window, but a fan and light...
Where customer wants to have single switch that can turn on both light & fan for when having a shower...
But another switch to turn on just the light for when only using the loo...
(in this case the light is equivalent to the dust extractor...
and the bathroom fan the equivalent to the saw..)
So if the light is wired via 2-way switch sort of arse about face..
Perm Supply to L1,
Lamp to Common
Switched supply from fan to L2...
So if the light is switched on its perm live via L1 and Common (but NO feed to the fan).
if the light is switched off it will also become live if the fan switch is turned on.
e.g. light switch will ONLY turn on light
Fan switch with turn on fan and also light even if light switch is turned off...
Done it for a bathroom with a double gang switch, one marked Light other marked Light+Fan…
Not sure if this concept is adaptable for this scenario though... especially 50m apart!
Guinness But the logic is do-able.
You can’t do that and comply Andy.
How about a wireless switch for the fan with button at the saw? That way the controls aren't linked and if the emergency stop is activated at the fan, or machine shut down for maintenance, it won't have a secondary live supply.
