- Feb 10, 2009
- 342
- 17
I have to install t&e cables in the following environments so i'm interested in other's opinions as to appropriate Installation methods
Firstly, stud wall constructed as follows:
a) 47mm x 140mm Stud
b) 12mm OSB external to stud
c) 100mm celotex between studs pushed up against OSB
d) 12mm celotex inside face of stud
e) 12.5mm plasterboard on top
If cables are installed in the 40mm or so void between c & d is this comparable to Installation Method 2 (Ref Method A) ? - Ok, there is no conduit but the solid insulation will create a similar consistent air gap.
Or is it better to install cables between d & e - which I see as method 102
Secondly, cables in capping against existing masonry with 25mm + 12.5mm celotex backed plasterboard dot & dabbed over. - can this be considered to be 102?
Thanks all.
Thanks all.
