Optima Default
Try:-
1  Remove mains...cause alarm by removing bottom half of cover...disc.battery.
2  remove all wires  ...........................   JUST THINKING ...SHOULD THIS BE ON OPEN FORUM?
if it works!
Ive had some that just refuse to crash point blank,
others that take 4or5 attempts.
I have had that with other makes, even top of the range Scantronic. When you speak to their Tech & quote your version number its always ' yeh, that burns in on that version, tough'
Try:-
My 1 page was the full instructions for an old original style  Optima panel. These  & the latest are availible freely all over the net such as here
http://www.theelectricalcompany.co.uk/manuals/Optima_Intruder_Alarm_manual.pdf  P17, Resets. So no secrets
OK there is :-
1  Remove mains and cause alarm by removing cover.
2  Remove all wires from 13  and 23  , fit a link between 13 &23 & apply power.
3   System will power up with no alarm condition.  Remove link and replace wires, check that "Attack" ind goes off.
4   Refit cover.   Check that TAMPER is off.
5  When all the zones are clear the NVM should clear and back to factory setting .
