outdoor socket
pscrase
Jan 15, 2010
4
Hi everyone I'm new to the forum It's a question about a socket outdoor the consumer board is not RCD would I be ok to put in an IP 66 sockets with RCD outside a weatherproof one does that satisfy the regulations
Yes whatever work you do has to comply with bs7671 and im sure would be notifiable too
All so depends on where your running your cable from, if it's going to be run inside the house and buried in a wall less than 50 mm deep then the cable will need rcd protection. So an rcd fcu may be needed and then a normal ip socket outside.
