..and I would say that would be the end of the ringed circuit.
Errm, the end of a ring??? That is like saying the end of a rainbow....
Here is a drawing from the regs to do with spurs and sockets
john...
So far as i know you can wire up what you like in your garden shed, all NOT notifiable
According to NICEIC
john...
Technically there is a way around it, suppose your shed is just having a couple of lights and sockets and the load isn't that great, you could wire it as normal, but instead of hard wiring back to the house, put it on a plug, that way part P doesn't enter into it. That's one of the reasons there's been such a growth in the sales of those outdoor sockets that come with a length of TRS flex on them and an RCD plug, screw it to wall, bring cable into house, fit RCD and plug it in, there you have it, an outside socket with no need for notification whatsoever.@apprentice87, just to clarify, you are effectively saying that anyone can wire anything up and it is not notifiable as long as it is not connected to a supply?
I'm not sure in what scenario putting power to a shed isn't notifiable, unless I am missing something.
Dear god, is that the best advice available?
Since when has the NICEIC taken precedence over the IET?
Jaysus FK JohnOk according to the NICEIC:
Electrical work carried out in the garden is no longer covered by
Part P of the building regulations in England.
This means
it does not have to be notified to your local building
control department.
Part P does still apply in Wales though. The following is an example
of electrical work in the garden which must be notified to local
building control (Wales only).
A supply to a detached garage, shed or other outbuilding
A supply to an electric gate or pond pump
Garden lighting
A socket-outlet
Before starting any work, you must notify your local building
control office and pay the appropriate fee for it to be inspected.
I think that is pretty plain?? What is hard to understand about that?? It clearly states as an example; "A supply to a detached garage, shed or other outbuilding" and it clearly says "Wales only"
Once again, here is the link, read it yourselves...
https://www.niceic.com/www.niceic.com/media/PDF/FactSheet-Garden-A4-4pp.pdf
I do not understand?? The subject at hand is part "P" of the building regs. and what is notifiable and what is not. What has that got to do with the IET??
john..
Exactly, hence my point about putting a shed on a plug, and it can be done, a shed isn't classed as a permanent structure unless it is on a concrete base and is bolted to it, had this over a planning argument, some guy saying you needed planning for a shed over a certain size, you didn't! If it was secured to a concrete base then it was a permanent structure and needed permission, if it wasn't then it didn't need permission any more than you'd need planning to put up a large tent in the garden.Just as a side thought to this, (Phil's comment re caravan lead made me think), Anyone can do whatever wiring they like inside a caravan, be it 230v or 12v supply stuff. There is no notification rules or any legal obligations about any aspect. Yet a caravan is effectively a metal shed on wheels that can be left connect to a mains supply in a field, where any other third party, (children pets etc), could potentially make contact with its metal structure and/or parts of its DIY electrical work . Which could be connected to a 10A or 16A RCD protected supply. Looking from that perspective a shed is an easy safe option.
^^ re sheds, some do in fact need planning permission. Where I live, the deeds for the entire estate state that any garden structure needs planning....all the borough, you need planning permission if you make your drive larger by 15 sq meters, you need planning unless the finished surface is permeable
That sounds a bit like some private small plots I know of, approx. 15 or 20 properties, off a couple of cul-de-sacs, with automatic gate across entrance road, (though gate opens without any code entry, gate is just to make it look posh). All residents have to pay toward the upkeep of some communal grass land in font of the properties. No one is allowed to erect any garden structures, or put up TV aerial, (all aerials in loft), or satellite dish on outside of buildings. All about keeping an 'exclusive' appearance to the plots. Though this isn't council permission, its some private association who manage it all. So you could do DIY electrics but not put up a 4'x6' shed.
A bit of snobbery with places like that, a mate's daughter bought a place some years ago, they were buying a new house and chose this particular one as it had space at the side of the house to park their caravan, thereby saving them storage costs, so they brought it home. That's when the trouble started, they were politely informed by the "residents group" that parking caravans was not permitted, it was in the rules apparently, neither was garden gnomes, satellite dishes or older scruffy vehicles! Non of this was pointed out when they bought the property, there was a case on tv recently when a guy was told he couldn't park his works van on his own drive! Personally I couldn't live somewhere like that, I think it's some kind of plastic snobbery, the irony of it is that usually these people who think they are somebody haven't got 2 pennies to rub together.That sounds a bit like some private small plots I know of, approx. 15 or 20 properties, off a couple of cul-de-sacs, with automatic gate across entrance road, (though gate opens without any code entry, gate is just to make it look posh). All residents have to pay toward the upkeep of some communal grass land in font of the properties. No one is allowed to erect any garden structures, or put up TV aerial, (all aerials in loft), or satellite dish on outside of buildings. All about keeping an 'exclusive' appearance to the plots. Though this isn't council permission, its some private association who manage it all. So you could do DIY electrics but not put up a 4'x6' shed.
