PIR outside light. Is it acceptable to use a spare 6amp mcb with rcd protection in CU and run 1.5 mm arctic blue straight to the light?
So in effect using the mcb as a switch / isolator if required.
This is just to cause the least amount of disruption to internal of house - i.e no need to chase in a switch and the cable coming to it.
