gavindrummond
Hi as I'm a student I need help with this. My missis ex has wired up an outside sensor motion detector light. And has supply has come off a 13amp fused spur in the kitchen. Am I right in thinking it needs a 3amp fuse in there as the 13amp fuse would never trip as its too high? I checked that it's on an RCD which is it so I'm happy with that. He wired it through the wall then on the outside cable clipped it up and across which was stupid as it should have gone straight through the wall at the actual lighting point through the joists then run down and chased in the wall in the kitchen. I have some pictures as I run it in conduit today. Reasons being to give it more mechanical protection and it looks smarter than what he did.
