Thanks for reply’s, here goes I’m going to get 3 recessed down lights, each pointing down the brick coloums at the front, and going to get a dusk till dawn sensor. I’d like to have a switch but not sure if there would be enough room to replace 2way switch with 3way switch, would it be a tight fit? If that’s the case and it’s to tight I’m just going to run a cable from existing switch. I will post a couple of photos of wiring etc once done
Would replacing a 2gang to 3gang be to tight?
