Hey Paul my new found mate what is your profession just incase I need a favour?
perm live - comm
switch live (black sleeved brown) - L1
neutral (grey sleeved blue) - to neutral in original switch
earth (sleeved green/yellow) to - E
now if you ask for the connections at the other end .................
Draw what out sharpend?Thanks I am grateful that you could draw it out. :happybunny:
Just seen this thanks mateSomething like this I think is what is being described by both you and others.
1mm² cable should be sufficient and easier to terminate.
Having the three core from switch to sensor allows more capability at later times if it is required, even if you do not install a manual override at the moment.
What’s that supposed to mean?
Just to note that the wooden baton isn’t actually part of the structure of the house. It’s just a bit of wood on the inside of the soffit that the soffit is nailed to.
Bit of a random question tbh, why would you ask if I was from Essex? Why ask that? Also asked you a simple question what’s that supposed to mean? But yet you cannot answer it.It’s a simple question, do you take offence at it? If so why?
