The brewery has a large vessel with a pair of 18KW TP immersions in - they`re on for about 2 hrs every hay; at the same time, to vigorously boil the mixture.....
When they were originally installed ( by others), they were wired in 6491x, through flexi conduit.
But - the junction temperatures are baking the connections - two of the lugs have come detached on one unit.
I`m going to be rewiring the units in the morning, with glass mica insulated cable - 250 degree operating temp - but the connection to the pins of the immersion is going to be an issue.
They will not sign off on replacing the immersions (>£300 each), as they`re working.....but I`ve got , effectively, rigid copper bar sticking out into the terminal box.
Any suggestions as to re-attachment? I don`t think solder will work, leaves compression ( iffy on solid bar) or something else, like a miniature CV spring??
