had a good one with a builder a few weeks ago.followed by builders who openly ignore the regulations, t
They are fully aware of the situation, there have been letters posted in voltimum and the ESC receive letters all the time.I really wish we could get someone that makes these kind of decissions from either the government or Summit or JIB or EIC on here at to listen to "real problems" that normal electricians have to deal with day to day and the trouble it has become to even get in to the trade the way they want you to ! ! !
but someone that has just come out of training should have the NVQ to prove it, not just a part p quick course. your c&g's are more than enough, because you didnt have the problem of 2 week/1 month courses when you were completing themI have worked for a large multinational, I have all My C&G barring 2391, but no NVQ, as I quit partly due to the fabrication of NVQ work around Me. I can install most things on bigger jobs, just dont have the NVQ to prove it.Andy
i agee, its not clear what is a qualified electrician all depends when you did your course and/or what the scam providers ask for e.g. if was not in this industry then i did a quick course and got accepted on to a part P scheme id consider myself qualified but everyone on heres nows id no where near good/safe enough to go alone or join a company and be put on the same rate as the rest of the sparksI can certainly see where you are coming from KT, but its the fact that there have been so many changes in the last 12 years or so, that sparkies are really getting fed up with the chopping and changing.Andy
Have you got Tony for your assessment mate?i have my assessment coming up in a few weeks i will get it from the horses mouth.if they implement this then the industry will be in trouble and will not be able to police the part p
all the guys not having nvq 3 will go underground,,,,still do a good job produce certs but not notify
lets be honest how many customers give a t#ss ?????
please refer to my signature for further ref.
yep as usualHave you got Tony for your assessment mate?
really ????good theres too many two week course "electricians" out there under cutting everyone
No, as GH says a bad sparks can be determined by many factors , do you follow the regs ? Do you cut corners ? Do you leave a job thinking that will do ? Do you use quality equipment made to the proper British Standards ? If you was unsure of something would you ask or would you do what you "think is best" ?So I started my electrical training in 2008, did a 12 week full time course to get my 2330 lvl 2, then did the 17th, then about 9 months later did another course to get 2392 T+I, and have spent most of the rest of the time working with old time sparks in order to learn my nitty gritty.Does that automatically make me a bad sparks?
Good luck on the 15th You don't need it really as you will be fine and know what to expect. Coffee and chocolate biscuits is the order of the day. On the NVQ level3 requirement I'm sure the assessor told me that if you was already registered then this did not apply to you. Maybe worth asking Tony when you see him on the 15th mate.yep as usualnice bloke
15th April
---------- Post Auto-Merged at 11:03 ---------- Previous post was made at 11:01 ----------
really ????
or is it your'e over pricing ???????
2330 lvl3 a bit more in depth but I do agree that working with other sparks gives you experience but can sometimes teach you bad habits. When I've done testing with other sparks they have gone about it completely different to how I was taught in college but I can see why they've done it. It's quicker!! for a start. I've been lucky to have worked with a few sparks that have taught me a few tricks of the trade but it is when you're out there on the tools that's when the learning really begins.No, as GH says a bad sparks can be determined by many factors , do you follow the regs ? Do you cut corners ? Do you leave a job thinking that will do ? Do you use quality equipment made to the proper British Standards ? If you was unsure of something would you ask or would you do what you "think is best" ?What I am impressed to see I have highlighted in red.
This is a quote from someone working within the industry that has an offical input into setting the standards "what has been happening is people have been getting their 2330 Part 2 registering with a Part P scheme setting them selves up as an electrician and not really knowing what they are doing and ended up doing more harm than good" one example quoted to me was so called "sparks" that didnt know anymore than the 2330 part 2 chasing a wall to 50 mm just to run his cables in , making the wall dangerously weak ! because he had read in his OSG that if they wasnt they had to be RCD protected and he thought that ment it was ok to cut 2/3s through an internal load bearing wall ! ! !
This is why the structure of courses is being changed to make sure that people learn the stuff that cannot be taught in colleges from actually having to work on site with a "Qualified Electrician" .which you are doing. :Applaud :Applaud:Applaud:Applaud:Applaud:Applaud.
but then again I am still doing my 2330 Part 2 so what do I know :Blushing :Blushing:Blushing
Very true!!The one thing I don't think people have picked up on is if they are registered with one of the scams as a QS but don't have the necessary qualification to become a QS, if they get peed off with that scam they are stuck as they will not be able to join another until they get that qualification.
:ApplaudSo I started my electrical training in 2008, did a 12 week full time course to get my 2330 lvl 2, then did the 17th, then about 9 months later did another course to get 2392 T+I, and have spent most of the rest of the time working with old time sparks in order to learn my nitty gritty.Does that automatically make me a bad sparks?
