Small installation, with awkward roof, which is what is causing me problems, cos I can only get 2 panels on one string and 3 panels on another. This in turn means voltage supplied to inverter (s) is lower, and in danger of dropping out of min required for inverter should a panel be in shade, which in turn will effect performance of system. Hence I want to connect all panels to same inverter to maintain supplied voltage, but at the same time I want to protect the individual panels, so effectively I want to fit a diode for each panel. As it happens shading is pobably only an issue in early mornings and late afternoons in summer, so not convinced I am not worrying about nothing, but I would rather that, than firk it up.I never had a really close look at the Kyocera panel, but I think that you can get into the termination box; so may be able to fit the diode there?If it`s a biggish install, with a few strings, it may be better to fit the diodes internal to the property, on the string rather than individuated panels? finding & repairing a blown diode on the array would be a `mare!
KME
Will probably opt for wiring each panel back to roof space and connect up in large adaptable box.
