Personally I drill a smaller hole (16mm) and knock through some 16mm oval on a slightly downward angle and seal it with silicone..
I would avoid using cement on the inside as decorators hate rubbing it downcemented at either end to stop moisture getting back in
Applaud SmileyI would avoid using cement on the inside as decorators hate rubbing it downGood luck with the assessment.
Ian.
Dewalt do some smaller ones (e.g. this 8mm 600mm long sds+ http://dewalt.co.uk/accessories/productdetails/catno/DT9535/). These are fast cutting and need minimal hammer.Applaud SmileyWhere do you get the longer drill bits from in smaller diameter? Smallest I have found is 12mm at 600mm and 1000mm.
The stone does 'blow' btw!Move. I wouldn't have thought you would "blow" the face on a stone wall so drilling small then going up would not be so necessary.
