very trying it is....
Yes.Just bought a scanner off ebay for a tenner. its a symbol LS4000i barcode reader, when I checked on the internet for serial bar code scanners this was listed as such so being serial I expected it to have a serial connector plug. It has a sort of RJ45 with 6 pins.. Now I'm confused and not sure what to do now..... Can you get a serial/ rj 6 pin?
Much cheaper here. You could use an adapter, or just chop the RJ45 off and solder a DB9 plug on. Either way you just need to know the pin configuration of both bits of kit and away you go.Thanks Matty, I have seen an adaptor where there is a female RJ on one side and a male 9 pin and you can open up and swap pin configuration around.something like this perhaps?
