Those cheapo PIR 500w floods, I can't see the icons under the PIR as it is black on black , even worse when its fitted. :_|
Also , as we are expected to tighten the locknuts on SWA glands, why don't they make them thicker so your grips grip and don't keep slipping off. :_|
Also so called euro type enclosurers with those non standard PLG knockouts about 23mm dia. Yeah I know you can buy them but 20mm should be the standard. :_|
Also other Sparks who cut their cables back really really short in KO boxes. If you have to replace it, job becomes a nightmare. :_|
Dist. Bds that no one has bothered to mark up , can't just try 'em all cos of the computers/mainframe/ alarm goes into panic :_|
