bad work man blames his tools :_| :xdamn too slow! all down to my 'a' button not working and having to copy and paste every time i need one!!
Ok.Thanks for the comments, Init.Can I therefore ask you to provide me with the data you used to determine that every CU or DB needs a seperate certificate? Because I`ve always provided one per "installation"; i.e. from a REC metering position onwards is one install, AFAIAC
KME
The DNO do not do installations.I'd class an installation as every DNO supply point.
My red.You have been told off before about not qualifying your answers. Why am i signalled out for this when i do, and from what i can see there are others that dont?Now that is a worrying attitude. I suggest you stop and take a look at yourself. You are not the best at getting your point across, or the best at referencing your answers or the best at explaining things.Mr GH stated that he was the best ever born. I was merely pointing out that he wasnt. Again, why am i singled out for stating this?
ze is external earth loop impedance! you don't get a ze result for submains. thats the zs of the board or zdb!The DNO do not do installations.Anything south of their equipment is an installation.
Therefore, if there are two DB's or CU's with 40 circuits each, regardless of how many supplies there are, that would be regarded as 2 installations ad i would compile 2 separate reports.
After all, the Ze could be different between the 2 for whatever reason.
Hmmmm lets see.ze is external earth loop impedance! you don't get a ze result for submains. thats the zs of the board or zdb!an installation is 'an assembly of associated electrical equipment having co-ordinated charactoristics to fulfil specific purposes'
which doesn't take a genious to work out that a single DB isn't classed as an installation if unless there is only one with one source!
