Remember though you should not leave the newly jointed cable in a non safe route .
Hi firstly great pics and explanation it was just what I had in mind aswell! I need to move some sockets, only few inches but they need moving all the same.Just a thought to the OP.............you need to extend the cable (I assume you're losing the original socket?). First obviously keep the chase horizontal/vertical in line with the original socket. Why not go that bit deeper on your chase and lay in a length of PVC conduit? Any issues with your crimped joint and you can whip it out.
Tthanks for the advice, am I right in that should be 150mm from any sink/taps and hob/oven or should it be 300mm?Also don't forget that the existing cable as well as the extended part needs to be in the safe zone,,, directly in line with a socket or switch (horizontally or vertically) and within 150mm of an internal corner or where a wall meets the ceiling
According to the various guides to the building regs it's 300mm from edge of sink/hob to edge of socket. Think the NICEIC reckon ideally 1m. Not of course always practical!Tthanks for the advice, am I right in that should be 150mm from any sink/taps and hob/oven or should it be 300mm?
Says I dont have permission to view the image.... for some reason?
Just saying
