Please help me understand my light circuit
Lipple
Feb 6, 2025
UK
Hello,
I am replacing my pendant light fixture with a low profile (metal) fixture.
I read a good bit and saw how light circuits are wired using the 3 loop method, wired inside the ceiling rose. There is no space in the new fixture, so I figured I would get some wago connectors, a junction box to hold them in the ceiling and some new cable with an earth line, repeat exactly the wiring in the rose and I'd be all done (to be honest, I think I can still do this as long as everything is wired up as it is in the rose, but I want to be sure)
When I opened the fixture I did not see what I expected to. See picture. There is nothing in the loop. I thought perhaps it's the last light on the circuit, but the other lights are wired the same way.
In the switch I got very confused, there is two wires (not colour coded) going into one end, and a live (or switch live?) in the other. See Picture. It sort of looks how they might wire a 2 way switch. But there is only one switch controlling this light.
I cannot make sense of what I'm looking at. There is a smoke alarm in same room which is almost certainly on the same circuit if that makes any difference.
Could you help me understand how this is wired? And maybe confirm if I repeat exactly the way the rose is wired using wagos, that all will be right?
Thank you.
How old is the property? The wiring?
Looks like you have singles with earth cables.
So easy to use lever wagos and don’t worry about containing them in their own enclosure - as long as the base of the new fitting covers the wagos you are good to go
Property & wiring are brand new - 2023.
But okay, that's good, thank you.
I don't think there is enough space in the new fitting for the 3 wagos I will need. If nothing else I'd have to drill a hole in the fitting base just to fit the extra wires. So I think I'll have to put the wagos in the ceiling.
wired in singles by the looks of it. all neutrals looped through the lights, perm live looped through switch & a SL from switch to light. neutral & SL having a cpc and the perm live no cpc
not a common way to do it but still an acceptable method, although current standards recommend a neutral at the switch
