please help!
paul b b
May 26, 2009
1,751
stuck between a firm pair of t***
hello chaps,
i'm doing a second fix for a spark who has gone off on holiday for a month and landlady wants the tennant in.
anyway....he has wired the hall/landing light in a diferant way to me, he has twin x 2 going to rose (feed in/out) and a 3c&e? this goes to a switch with 2x 3c the other goes upstairs, the landing switch has twin (to pendant) and 3c...
please help:D
I'll try to describe it , Paul , not good at posting drawings, it should give you the idea.
3core from hall lt to switch is a live, a neutral and a switch wire back to the hall Lt.
The other 3 core in the switch is a pair of strappers and a neutral to the landing switch.
The 2 core from landing switch to light is a switch wire and a neutral.
Neutrals go in connectors in the switch boxes.
Oh and loop a jumper feed between your 2 gang switches ,
Jobs a good 'un.
( If it blows up my name is Specs)
Now he tells me:O Where is this switch situated ? If the 3core passes through it on its way upstairs then my guess is its an intermediate, if so , put connector on the neutral again and connect your strappers in and out of it.
Make sure you buy an intermediate switch for it.
i was worried you were going to say that, its a 4 gang switch and this is the only one thats needs it.
thinking about it though, i think the other switch may only work the downstairs light.
i think the 1st sloution was correct
thanks again
