- Nov 28, 2009
- 14,690
- 846
Todays job. "sort out" the wiring for the central heating.
It's an electric boiler (on E10 tariff) originally wired (I think) by plumber No1
Then later plumber No 2? added a wood burning stove with back boiler.
Original (plumber No1) wiring looked reasonable. Until you looked in detail. T&E connecting room thermostat with CPC as switched live (give him a little credit, he sleeved it red)
Plumber No 2's wiring was a joke. all wired in flex, just plugged into a 13A socket. But the pipe thermostat that was supposed to turn on the pump to circulate the heat from the stove, was wired in PARALLEL with the supply and the pump.
The main complaint from the customer was the stove pump does not come on automatically, and when he turns on the 13A socket feeding it, sometimes it trips the MCB in the CU. Wet Fish
I was there 6 hours rewiring the lot. This was supposed to be a quick job.
