- Feb 27, 2008
- 11,018
- 0
It is rated at 13 amps try plugging two 13 amp appliances into it and see how long it will last.no its not its obviously 26Amp
Batty
I am sure this happens quite often..nothing happensIt is rated at 13 amps try plugging two 13 amp appliances into it and see how long it will last.Batty
not using my electricity i wontDepends on make of socket for one thing and obviously how long things are plugged in but try plugging two 3 kw heaters in see how you get on.Batty
Hang Five minutes NT, I will just nip round to batty's and plug a lead in so you can test it with his electricty......not using my electricity i wont
Yet again you are showing yourself up. X(no its not its obviously 26Amp
That's a good point Batty, but in reality very unlikely someone is going to do that..Depends on make of socket for one thing and obviously how long things are plugged in but try plugging two 3 kw heaters in see how you get on.Batty
I know it unlikely the point I was making to our friend is that a double socket is rated at 13 amps not 26 amps. I remember reading an article about testing 13 amp sockets. They where tested over a period at a greater rate than 13 amps. Branded ones like MK stood up best but at about 19 amps they did suffer damage. But I have seen double sockets under sinks Etc used for plugging in two appliances. I would always put in two single sockets.That's a good point Batty, but in reality very unlikely someone is going to do that..Pray
Simple if you know how!Can I make a point regarding the loading of sockets?A well know manufacturer of socket outlets (desk top solutions etc), overcame the loading issue on strips (as indicated by clients) by wiring them in a 2.5mm ring (internally).
Don
Who might that be?A well know manufacturer
Quite right, that's why there will always be 'discussions' about it.Point taken, but the Don boy's have worked at a leading manufacturer of multi point outlets.A double socket is protected by at worst case, a 32A MCB.
A double socket can have 2 x 13A plugs connected to it.
A double socket must be capable of passing 26A without exceeding a given temperature, according to CE tests.
(Apologies I don't have the details to hand at present)
Don
Take your blinkers off, its 13A PER SOCKET ,Yet again you are showing yourself up. X( Go and find a double socket and look at the back of it. You will find '13 Amps' marked on it NOT '26 Amps' FFS!
If you think nothing happens when 26A is drawn from a 13A socket then you're a fool. :_|
