It still is for any self respecting spark.At the foundry PAT testing was regarded as punishment duty.
Back in the day one of our clients used to fit those 3 pin Duraplugs to heating pumps, the idea being that when the plumber changed a pump it was just a plug in, no need to send an electrician as well. Some poor sod had to wire these things so they had a stock of them, if you upset the gaffer or you were at a loose end then you were it. It carried on for ages until one of the boss's who happened to live in one of the associations property's took a dislike to them, Apparently his heating pump was in a cupboard in a bedroom, his young son pulled the connector apart and poked a paperclip into the socket portion, it wouldn't have been so bad but the heating was on at the time, thank god for RCD'sIt still is for any self respecting spark.
dura plugs
we use dura plugs on fire engine charger leads, theory being if the driver forgets to unplug before racing out the doors the dura plug will disconnect...............would work if the thick twats wouldn't tie the up stream cable length to the side of the wagons...............a Marcaddy reel rattling across 3 tunns junction in slough is rather amusing during rush hour.
They also make...
A Duraplug what?
I think this is a regional thing, first thing I think of is a heavy duty 13A plug. I assume you mean something else.
Tried them but had an issue with them arcing when plugged in...........the weight of the hanging cable
