thanks Doc, and theory, logical approach to the diagnoses is,
customer has a leak at the boiler calls out a plumber,
plumber replaces a potterton boiler, with a Baxi boiler,
he also replaces the PCB, I presume he must have damaged it or it just gave up the ghost,
plumber leaves, a few months later the the elderly lady notices that the CH and the HW seem to be permanently on
even if room stat is not calling for heat, customer is turning the boiler off and on to regulate the heating and hot water.
I dont know what the plumber has done regarding connection or disconnection of any wiring.
Customer calls out a heating engineer, he say's that a motorised valve isnt working correctly and he say's his electrician friend would come round and sort it,
well no one has turned up.
I said I would have a little look to see if it was anything obvious,
I have installed a combi boiler in my own home and understand the basics of a heating system,
however this system had a Baxi boiler down stairs feeding what looked like a heat store type vessel in the airing cupboard,
the pipework has 2 motorised valves, and 2 pumps, which I guess is a closed S Plan setup,
on removing the faceplate of the heatstore vessel I came across the PCB and all its connections,
all the cables have been labelled and everything appeared to be ok,
I haven't done any testing yet, my thoughts were to ensure that the wiring at the PCB and ancillaries is all connected correctly, then to set the room STAT to call for heat, then to set the tank STAT to call for heat and see what happens,
if the wiring is ok, could the fault be due to a stuck open valve?
and if so, how difficult is it to replace, I guess the system would have to drained first, then replace faulty valve and refill
sorry this is long winded, thanks for any help much appreciated (MEERKAT)
