Central heating boiler at church causing me grief. It has been OK through the really cold weather. In fact I left it on 24/7 as I thought the pipes might freeze.
Now it will run for an hr or so then stops. The green LED goes off and the red one flashes twice per second. I looked it up in the manual and that just says 'Lockout' You press the re set button and it comes on again.
This is a PITA because the timed settings should make the place warm before people start coming in but as it locks out after an hr, unless someone is there to re set it will remain cold.
Anyone got an idea? failing that a reputable gas heating eng in Blackpool that will come out this week for a reasonable fee?
James
James
