I thought that title would generate some interest. As you will know from the regs we work out power used in any form of discharge lighting by the formula; lamp watts x 1.8. I am doing an assignment for a design course and as there is a huge amount of fluorescent lighting involved it would be better to know an actual figure for amps used per fitting rather than using the 1.8 factor. If I use the 1.8 I will have to split it into too many circuits or use 2.5 for the wiring.
I have done a google but not come up with anything. I need a data sheet for a 4 x 36w modular grid ceiling fitting that shows me the current demand for the fitting.
headbang
Any ideas?
headbang
Any ideas?
