that was known as the "spider system"In older days JB's were used under floors to save cable some with 10 or more cables going in to them.
WP box?Some sparks still use spider method. I would use it on rewires if existing conduits are being used and there are a lot of downlight/wall lights etc. I would use a WP box with wagos though.
If you were putting three conductors into one connector you need to have all the conductors cut ready, then hold them in in the connector whilst you screw the terminal down with your other hand. With wagos you can terminate each individual conductor in turn, strip connect, then the next. Less risk of conductors floating loose out of the joint before you have the screw tight.Ty. Are those wagos as good as they look?
