Hi Paul,
I can see a bit better now!!!!
Here is the contraption concerned!!
Lust lust!!!!! ha ha
Apparently it will cut 18mm plate. Personally though, for anything thicker than about 8mm, I would much rather O/A, either hand held, or with my Pug, but there you are!!
Very impressive bit of kit though, best thing is, that you can use templates made from simple cardboard and just go round them, oh, and of course it cuts ally and stainless too, and galvanised sheets without wrecking the galvanising too much!!
I also bought this swing head bandsaw!!!
Even more lust!!!! ha ha!!
The saw came from a training place where it had only been used to demonstrate the process to people before they went on to be trained to use monstrously large ones!!
For bar stock, my Qualters and Smith hacksaw is the business, but for box section, the band saw is the thing!!
It has two speeds, [two speed motor] a proper coolant system, cam operated quick action vice, it is great!!!
The Capacity is as follows:-
At 90 degrees - 225mm dia. tube, 200mm box section, 250mm x 150mm rectangle
At 45 degrees - 160mm dia. tube, 155mm box section, 160mm x 120mm rectangle
At 60 degrees - 100mm dia. tube, 100mm box section, 100mm rectangle
So, that will do me!!!!
Love my new toys!!!!
john..
john..
