- Mar 28, 2008
- 14,269
- 922
Great photo's & good info..Yes - it's a pull cord switch.There is a fan (with switch to have it turn on automatically with light, or not).
There is also a shaver socket (I'm not sure if this is important or not).
There is no switch outside the bathroom.
So - as I know very little about these things, I assume you would recommend that I call out a professional to look at it?
Would this be costly do you think?
Thanks.
Just to add my four-penny-worth to the other guys input...
a) In general most modern light fittings have naff all space to conceal any significant amount of wire. and the connection terminal strips are only just big enough to fit one wire in each connection 'L', 'N' & 'E' !
B) is there access above the ceiling?
personally if it was me i would try to move all of these wires out of the way and just have one twin & earth cable coming through the ceiling.
which will make it easier to fit your new light & replace that at a later date when you buy your next light!
and reduce risk of heat from the light affecting the cables.
Assuming access above ceiling (e.g. loft void) it would be very easy to install a suitable junction box to tidy all of these wires into!
Or alternatively you could have a circular dry line box cut into the ceiling behind the light with suitable connections made inside.
c) Assuming a worst case scenario where need to meter all of the wires out verifying polarity & connections & boxing away from the light fitting.. It shouldn't be more that a couple of hours Max... more realistically 1 to 1.5 hrs
d) One other thought.....
You say there is a fan with another switch to turn it off/on (when light comes on). Is there a separate fuse unit as well.
Many extractor fan manufactures instructions recommend a 3amp fuse it put in the fan supply? possibly may be worth considering whilst tiding these other wires up.
Oh by the way..
Welcome to the forum
