ah!!!
the big Low energy light bulb con raises its head...
Several manufactures bulbs say in the small print on the back..
Not suitable for use with Dimmers.Not suitable for use with PIR switches.
Not suitable for use in Enclosed light fittings.
No use in a pantry or under stairs cupboards cuz take to long to get bight!
plus the fact that many are too big and ugly to fit in the lamp holder!
It is not uncommon for them to fail within a couple of months even in a bog standard manual type light fitting....
I have lost count of the number of Low energy bulbs I have thrown away after less than 4 months.... (although they quote several years life!!!
X( )
You can also get the old "starter type" failure, e.g. lamp gives slight glow but won't fully illuminate.... but no starter to pull out and replace:_|
I am not convinced the full life cycle costs of the bulb is actually any true savings.
Also to add..
read the small print on the back of your PIR sensor box...
e.g. "unit capable o switching up to 2000w, NOT recommended for use with energy saving lamps"
other than that they are great!!!!
