hemant,
You have joined a serious forum, it's just we try to have a laugh while we are here.
You may not think that anything has been gained from the previous posts, I think you are wrong!
You mentioned an AAA battery, the energy capacity of this was questioned by the Rev.
Steps came back and suggested that even a watch battery could hold enough energy to do this, but perhaps only once.
So you have had some valuable info.
Also NO ONE has accused you of attempting to make an incendiary device.
As i have just finished off my work for the day I'll try to put something helpful together for you, but you will have to give us some more information.
At what level is this project?
GCSE, A Level, ONC/D, HNC/D, 1st Degree, Masters, PhD?
The academic level will have a bearing on the complexity of the device.
First thing is you need to establish the liquids that are to be heated, then find their specific heat capacity.
You need to estimate the delta T.
You need to decide on the ambient temperature limits through which this device must operate and reach its final 180/200 Deg C
Then you will need to estimate / model the heat loss during the procedure, it is doubtful it will be adiabatic.
(See guys told you it has other uses, different form though...)
The problem you have immediately is the small volume of substance, small volume in a large container = large heat loss.
Once you have these factors you are then in a position to decide how much energy you need and in what time period.
From this you can look at the energy supply needed.
You will then need data on the AAA battery, different makers will have different capacities as will different battery technologies.
Will the same battery power the control system?
Remember a basic resistive control will dissipate energy, thus wasting your available energy reserve.
Have a think about this then come back to us.
