I haven't got any fuse yet Plumber. I take you're point about discrimation. I'm going to speak to the DNO on Monday to explain the situation and see what he'd prefer that I do.Damien, id be carefulWhat size fuse do you have? 80 amp?
Think about it, do we need discrimination of circuits?
Are you going to provide discrimination between the switch fuse and the dnos fuse?
If you are then you may struggle to achieve discrimination between the switch fuse and the larger mcbs.
If theres little to no discrimination between the switch fuse and the dnos fuse whats the point fitting one.
Speak to your dno explain your circumstance, explain the distribution circuit will meet the regulations and that all is needed is a double pole isolator for disconnection of the distribution circuit from the meter tails
