All i have for my broadband is a usb cable into a box then a single phone cable into my adsl into the phone point. So for me to network i will have to buy a router for my usb to plug into that then my router will be live and then run an ethernet cable to my ps3 from the route to start to play online which i think is right.
If not please explain and also what would you recommend for a good router to do this cheers.
I presume at the moment you have a USB powered ADSL modem,
which will become surplus to requirement because I think all you will probably need is a reasonable wireless router.
been a while since I checked spec's etc.. when I bought mine..
but I think most wireless routers include the ADSL modem..
and have a few RJ45 ports on the back to allow 'wired' or 'Wireless' connection.
you have to program some setting first into the router
(with it connected directly into the back of a PC with an RJ45 patch lead)
i.e. to give the network a name & password that your devices can access,
but bar others with local wireless kit from piggy-backing your network.
So the router just plugs into the phone line..
your wired or wireless devices access the broadband via the router.
For example..
at our house we have a wireless router.
My PC has a wired connection plugged into one of the four slots in the back of it.
We then have either two (or three, when my eldest comes back from Uni) PC's also connecting via wireless cards..
and my youngest lad can also connect his PSP though its wireless link
just to show my ignorance..
Does the PS3 have a wireless card or a RJ45 socket??
if so.. should be no problem!
Who is your ISP..
sometimes they have particular recommend kit for routers??
that run the broadband side of the link better without locking up!
Other than that its a matter of checking the spec of each one..
the more expensive ones often have better range and signal strength for the wireless connections.
Pros & cons higher signal strength better signal for you..
but also your neighbours.. if you don't enable the routers security setting!
P.S.
The little ADSL adaptor that plugs into your phone socket is just a filter arrangement to stop you hearing the data when you are on the phone!
