Michelle0601
- May 9, 2017
- 8
- 0
Hello there I'm having trouble with my boiler and I'm hoping someone can help as I'm at my wits end! For the last 5 years I've had an old pulsacoil 2000 boiler which only supplied hot water when the on peak was switched on for an hour or more, I assumed this was a fault with the boiler and learnt to live with it until I could afford to replace it
I have had the boiler changed to a brand new one also by gledhil and I'm still having the same problem, as I'm on economy 10 I have had the electric meter changed as i suspected the time switch may not be working and this may be why the off peak isn't kicking in however this did not solve the problem, the off peak socket has also been tested and when connected to a different power source works fine, i have hot water when the on peak is switched on but that is all
The heating engineer advised to have an electrician look my consumer unit as he believes the fault may lie with the contactor in there as thats responsible for switching from on peak to off peak, I have paid 200 pounds to have this contractor checked and replaced but still no power supply to my offpeak switch, I have no idea what or who to try next! I do have photos but can't work out how to upload
