Kermit strikes again!
Thanks for thatfor those of you interested the EMT for this rod is less than a metre from a CU with extraneous metal that is supplied by an exported TNCS![]()
ray
Newman, Im still trying to make some headway with this, I havent forgot
This could be the problem,been up there and removed the offending muck .........I will keep you informend,waiting for a frosty morningIIRC panels with a greater than a certain percentage of shading, such as bird dirt etc. will shut down and not generate in case they bring the array down.
If they are good panels this should happen IIRC, and if they ensure that they do not become a consumer of energy once shut down this should be OK.
