The only thing that survived the Chunnel fire IIRC.
Nothing wrong with it, perfectly fine, should be used more IMHO.
It is the only cable type to pass all the fire resistance tests on the same bit of cable, IIRC al the "FP" types can only meet one of them at a time.
However, apparently that is OK?
Keep your Pyro, change your (incompetent) electrician.
The ONLY reason Pyro will "break down" is as has already been suggested poor installation, modification, damage or maintenance.
Perhaps apart from looking to your current, so called, spark, you need to look back to your previous so called, sparks, if you have, or have potential for, damaged "pyro" then it's their fault.
