You arrive at a lighting fault in an office there is a 600x600 modular fitting in the ceiling.The customer has changed the lamps and starters for brand new ones and now none of the fitting works.What could be the problem?
a.all lamps are faulty
b.he has replaced the fitting with wrong starters not suitable for a series circuit
c.he hasn't replaced the louvre causing the micro-switch not to make therefore not turning the light on
d.there is a fault to the whole circuit
I think its c but it does not say anything about the louvre in the question any ideas help please
