Robojin
- Jan 22, 2009
- 1,122
- 0
http://i645.photobucket.com/albums/uu178/robojin/Untitled-1.jpg
Came across this TN-S today, on the left appears to be a fuse which it is (cartridge type), but defo does not cut the power (not that I pulled it of course O) ), so I assume the block in the middle is the fuse, but would appear to be double fused on both Line & Neutral if the casing shape is any indicator, and even if I had contemplated pulling it, it's firmly in place no hint of any movement, although it does appear to have grips on the outer sides like the smaller one to the left
Also the smaller one has what appears to be a pair of 10mm tails holes top and bottom, reminded me of a type of Henly with a fuse ?:|
GH, AndyC thoughts on either questions?
