I was tackled by the QS of the solar company this afternoon - he`s currently teaching the PV course to sparx.
In the notes, was the following:
"The inverter is carefully designed to output a slightly higher voltage than the incoming grid voltage, in order to differentiate between the supplies".
He wanted my take on whether two different AC voltages, at the same frequency, could be present on the same cable - I say no. Further, I can`t see the inverter voltage being higher - it cannot "pull up" the grid voltage, FFS!
So he then wanted to know how your current-using-appliances "know" to use your locally generated electricity, rather than the grid.
My initial response was that, being "on-site", that supply had the "path of least resistance" to the load....but that doesn`t seem quite right, either.
So....how does "your" electricity get used, in preference to the grid supply?
e.g. If you & your neighbour are on a shared supply cable, you`ve got 1000W of lighting on, and your neighbour switches on his electric shower - why doesn`t some of "your" electric get used on his shower, wired in 10mm, with minimal impedance - THAT would be the "path of least resistance".....
Your thoughts, guys.
KME
KME
