Radiator Fitting - Problem With Valve Adapters
Tony Jaques
Apr 23, 2015
2
Stretford, Manchester
                 Radiator fitting problems
    I am sorry if my lack of experience results in my posing
stupid questions, but here goes:
1.
   My new central heating  radiator  has internally threaded
holes about three quarters of  an  inch  in diameter at both
ends.
2.
   The Lockshield valve on the  old radiator has an external
thread of about an inch in  diameter  (there being a  nut on
the old radiator). Obviously this will not couple to the new
radiator. I am guessing, but  there  seems  to be an adapter
between the valve and the old radiator, buried under several
layers of paint. If I  am  right  then  what is this adapter
called so that I  may  buy  one  -  if  I can't persuade the
original one to come off the old radiator?
3.
   At the other end  there  is  a  fairly  new TRV. Here the
situation is similar, in that the external thread on the TRV
is about three quarters of an inch in diameter, again with a
captive nut on the radiator.  Again  there may be an adapter
but in this case it is buried in rusty paint!
   In case I can't persuade that off what do I ask for?
   Looking at the  illustrations  in  the  Screwfix and Tool
station catalogues it appears  that  when TRV and Lockshield
valves are bought they come  with these "adapter" pieces, so
I suppose that I could buy  these  just for the adapters and
throw the valves away, but this leads to another question:
4.
   Are the parts that  I  need  standardised  - that is will
they fit my existing TRV and Lockshield valve?
   I am assuming that  the  10/15mm  is  a  reference to the
supply pipe and not relevant for me.
   So, sorry if I  am  a  pain  but  as the experienced will
readily see, I need some help!
Thank you.
Tony...
I don't think you can buy the stubs as a seperate item,,, they come with new valves.
The old standard had a 1" fitting,,, the new ones are all 15mm
You may need to buy a tool to remove the old stub but new ones just screw in,,, use plenty of ptfe tape..
If you have just invested money in a new radiator, you are best getting new valves as well IMHO...
As Noz said new valves have the right bits to connect to the radiator....
But you should be able to remove the old ones if you really want to, unless they have corroded in!
The inner bore of the stub may have a hex profile to take a drain key (or chunky Allen key)..
Or there may be a flat profile on the stem that a narrow spanner can fit around.
But new rad & new valves is the best solution to avoiding leaky joints IMHO!
:popcorn
Hello to all three of you.
     Thank you very much for taking the trouble to post those very helpful replies.
      Indeed I did find that the pieces that I needed were not available separately, but it only cost me £9 to buy
both valves from B & Q. Looking at the price of typical adapter bits that is barely more than the adapters
would have been if I had been able to buy them.
      Thank you for the tip about the allen key. As essentially an electronics man I didn't have one anywhere
near that big. But it was easy to find and quite cheap.
      I take the point about replacing the lot, but leaving the existing valves in place did enable me to do the job
without turning the water off, and of course it became just a "nut and bolt" job. I may regret the decision later
but I will see how it goes.
     So, thank you gentlemen; the help was much appreciated.
Tony...
