RCBO neutral and earth lenghts
Status
Not open for further replies.
Concur with him above wot replied earlier.. :) :Applaud :worshipyou cant really say much more than that can you!!!
just to add Iv'e cut em shorter as well in the past...
But I just make sure that should the need arise there is enough length left there so the RCBO could be used in any of the CU positions.
(incase there was some obscure reason that the CU needed re-arranging!)
A valid point, but I don't do this. If the need were to arise in the future then that's a problem for that time. I try not to cross bridges I haven't reached yet!
I always figure the leads could be extended with crimping if it really came to it, though I will leave a little excess if the neutral bar is directly above the RCBO so as not to shorten the lead to next to nothing.
Locked to prevent being resurrected (again)
Status
