Just a quick question, as I've got all you guys attention
Just going through some of the stuff I jave here and noticed something, if you can shed some light on it for me.
I have 2 dp rcbo's by 2 different manufacturers. One has the neutral to the right screw, the other has the neutral on the left screw... pic attached. This means i couldn't use a dual busbar if I want all of these connected next to eachother due to space limitation in the case, OR is it not a problem wiring these things either way around and the N stamp is merely a suggestion?
I know I can simply turn it upside down, and make the connection that way, but my OCD won't let me.
