Have just spoken to my NIC asessor. He has told me that if you have a TNS supply then this situation would be fine. If you have any extraneous, bond it at the local DB.
If you have PME the situation is fine if there is no extraneous conductive parts
If there are extraneous, TT the garage end, as has been done in the Picture part of this forum, labelling the earth as fictional & do nit connect.
His opinion is that my 'A' frame roof does not create another potential as there are no metal reed bars from the roof that are burried in the ground, it is just sitting on top.
The reason I knew nothing about this is because there is next to nothing in our regs regarding this and I have not come across it before. I had looked at 7671 and not come up with a lot. It is all very well you lot saying you can't do this & you can't do that but you haven't shown any evidence of where it states about this exporting the earth business & I don't know where to find it as yet.
No, I don't know wether concrete is conductive, I always thought we earthed it because of all the steel structure/reed in a lot of it that is in it. I've googled it and this is what has come up, two different types of concrete
Electrically Conductive Concrete: Properties and Potential
Answers.com - Is concrete conductive
I don't confess to know everything & I was always taught that you don't need to but, should you need to know anything, you can look it up and find it. You know what they say about the people who do... All the gear and no idea...
2391-20 is a 'proper' exam thanks. It replaced the old 2400 and prior to that the part C which, according to the JIB grants you Technician status. Yes it was a bit difficult especally as I did my 2391 in 2004, quite a gap, but was enjoyable and a good refresher. It's supprising how much you know, you've just got to dig back a but to find it.
I'm also going to ask my friend Sam on the exporting earth jaz. He's in his 3rd year of a degree to become a chartered Electrical Engineer. He also works for EDF networks (thinks it's just been bought out) and designs LUL substations.
The radiator (no I don't have one in the garage) was an example of the EZ. So the rad' is connected to the supply earth but the window isn't, they're within touching distance of each other and that is sitting on brick, upon concrete blah blah and then ground. The window isn't bonded, is that a different potential??!!
So, garden lighting, is that exporting the earth then. It's outside, outside of the EZ too??
I don't see the problem with the way my garage is done. What's wrong with it being on a 20A, it offers discrimination and to meet the disconnection time of 5sec required, ok it's a 3871, the regs still recognise these mcb's and eventually the board will be swapped, but it works and is safe. Ok, 6mm 5core is OTT but it was a leftover I had and
didn't cost anything. If I'd done it buying everything I would have done the whole run in the swa to save having a joint. The 20A also helps keep the Ib & In down so not to bump the cable calc up too much with all factors in and is plenty for what I'll be doing in the garage.
How did I pass my initial inspection and how did I pass my 2391-20, I don't appreciate those comments and your not here to judge wether I'm competent or not. I only signed up for a bit if advice and guidance here and there are, I assure you, there are a lot worse electricians out there than me and I am not a bodger.
Many thanks to those who have genuanly help,
Cheers
James
i forgot.... i asked where the reg was for the 600mm depth as i couldnt find this particular figure and wondered if i had missed something so wanted to clarify it and as it turns out, as the chap said, that was pulled from the ammendment that's not yet published.
i had looked up, with regard to my original question, and had come to the conclusion it didn't need to be RCD protected BUT just incase i had missed something i put the post up on here, as much as anything to see different people opinion as 7671 is open to interpretation and you could well understand it differently than i.
