Hello guys,
Before I call in an electrician, I want to see if I can do anything (As a DIYer).
So basically, I have a RCD in the kitchen, where all the switches are, all my sockets randomly stopped working (all light switches are still working), so I check my RCD and its turned off, so I switch it back on and continue what I'm doing, after about a minute the RCD turns itself off again, so I unscrew all my plug sockets and check the wires, everything seems correct, no loose wires or anything of the sort, so I try and test a few things out, and it seems using my microwave, toaster, oven and kettle (even using them separately) will cause the RCD to trip.
So I decided to keep on testing, I figured out, if I turn all my upstairs sockets off (using 1 of the socket switches in my fuse box) then all the downstairs sockets will work flawlessly, but if I then turn the sockets back on that are upstairs, the problem will start again.
I've got a feeling I'll need to call in an electrician, but I hope that maybe, just maybe, I could even fix it.
Thanks.
Thanks.
