I recently turned a circuit off at the consumer unit (which has RCDs built into it) and when I turned it back on it did not power up. After much checking I found this was because an RCD was plugged into a socket on this circuit and only when I removed this did the circuit power on when I switched the switch at the consumer unit.
I've not been able to find an explanation of why this happens.
How does the RCD in the socket prevent the circuit from powering up?
If the socket is turned off, how is the RCD even connected to the circuit?
Also, although I have RCDs built into the consumer unit I've always thought it safer to have additional RCDs in sockets when using lawn mowers and power tools. Should I continue to do this or would it better to rely on the consumer unit RCD?
Thanks in advance for any answers to these questions?
D
D
